Zum Hauptinhalt wechseln
JBL Pulse Speakers Replacement
Was du brauchst
  1. JBL Pulse Speakers Replacement, Button Board: Schritt 1, Bild 1 von 1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Speakers Replacement: Schritt 2, Bild 1 von 1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse Speakers Replacement: Schritt 3, Bild 1 von 1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Speakers Replacement: Schritt 4, Bild 1 von 1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse Speakers Replacement: Schritt 5, Bild 1 von 1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse Speakers Replacement, Outer Casing: Schritt 6, Bild 1 von 3 JBL Pulse Speakers Replacement, Outer Casing: Schritt 6, Bild 2 von 3 JBL Pulse Speakers Replacement, Outer Casing: Schritt 6, Bild 3 von 3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: Schritt 7, Bild 1 von 2 JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: Schritt 7, Bild 2 von 2
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse Speakers Replacement, JBL Pulse Disassembly: Schritt 8, Bild 1 von 1
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
  9. JBL Pulse Speakers Replacement: Schritt 9, Bild 1 von 3 JBL Pulse Speakers Replacement: Schritt 9, Bild 2 von 3 JBL Pulse Speakers Replacement: Schritt 9, Bild 3 von 3
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
  10. JBL Pulse Speakers Replacement: Schritt 10, Bild 1 von 2 JBL Pulse Speakers Replacement: Schritt 10, Bild 2 von 2
    • Remove cables by pulling firmly.
  11. JBL Pulse Speakers Replacement, Speakers: Schritt 11, Bild 1 von 2 JBL Pulse Speakers Replacement, Speakers: Schritt 11, Bild 2 von 2
    • Remove four black PH0 9mm screws.
    • The only thing still attaching the speakers is the wires to the soldering points. Cut wires at soldering points.
    • New speakers will have to be re-soldered to these wires.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 18-6, Blackwell Fall 2016 Mitglied von USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Mitglieder
8 Anleitungen geschrieben
8 Kommentare
Hi,
Thanks for your guide. Where did you obtain replacement speakers?
heaton.steven - Antwort
Hi. Even I would like to know a good replacement/ substitute speaker for this. Thanks
Vishakh A V - Antwort
Hi.
Even I would like to know where I can find a replacement or an alternate speaker..
what is the speaker specification that I can buy for replacement?
rbalagr - Antwort
Could you please share any links to buy these spare speakers ..Thanks in advance ☺️
deepak gupta - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 39
Insgesamt: 7,232
