Zum Hauptinhalt wechseln
JBL Spyro/Spot Partial Disassembly
Was du brauchst
  1. JBL Spyro/Spot Partial Disassembly, Locate the risers: Schritt 1, Bild 1 von 1
    • Locate the 3 risers the hold the base plate in place
  2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: Schritt 2, Bild 1 von 1
    • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
  3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: Schritt 3, Bild 1 von 1
    • With all three loosened remove the base!
    • Note the not equilateral placement of the risers when replacing the base.
Abschluss
17 weitere Nutzer:innen haben diese Anleitung absolviert.
Ryan McLeod
606 Reputation
2 Anleitungen geschrieben
11 Kommentare
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - Antwort
No problem!!
Ryan McLeod -
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - Antwort
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Ryan McLeod -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 17
Letzte 30 Tage: 103
Insgesamt: 13,046
