Zum Hauptinhalt wechseln
JBL Tune 510BT Faceplate Replacement
Was du brauchst
  1. JBL Tune 510BT Faceplate Replacement, Faceplate: Schritt 1, Bild 1 von 2 JBL Tune 510BT Faceplate Replacement, Faceplate: Schritt 1, Bild 2 von 2
    • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
    • Pull the earmuff towards the center of the headphones until it is free.
  2. JBL Tune 510BT Faceplate Replacement: Schritt 2, Bild 1 von 2 JBL Tune 510BT Faceplate Replacement: Schritt 2, Bild 2 von 2
    • Remove the three 3 mm screws using a JIS #00 screwdriver.
  3. JBL Tune 510BT Faceplate Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the faceplate by lifting it firmly.
    • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
    • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
    • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
Abschluss
Ryan
513 Reputation
4 Anleitungen geschrieben
Utah Tech University, Team 1-2, McMurrin Spring 2024 Mitglied von Utah Tech University, Team 1-2, McMurrin Spring 2024
UTAHTECH-MCMURRIN-S24S1G2
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 31
Insgesamt: 49
