Zum Hauptinhalt wechseln
JBL Tune 710BT Battery Replacement
Was du brauchst
  1. JBL Tune 710BT Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your JBL Tune 710BT headphones are fully powered off.
    • Gather your tools and a clean, well-lit workspace.
  2. JBL Tune 710BT Battery Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to gently pry open the earcup covering the battery. This is usually found under the cushioned part of the earcup.
    • Be gentle to avoid damaging the earcup or the internal components.
  3. JBL Tune 710BT Battery Replacement: Schritt 3, Bild 1 von 1
    • Once disconnected, gently remove the old battery from the compartment.
    • If the battery is adhered in place, gently pry it loose, taking care not to damage the compartment or nearby components.
  4. JBL Tune 710BT Battery Replacement: Schritt 4, Bild 1 von 1
    • Place the new battery in the compartment, ensuring it sits flat and secure.
    • Reconnect the battery connector, ensuring it is snug and properly aligned.
  5. JBL Tune 710BT Battery Replacement: Schritt 5, Bild 1 von 1
    • Carefully align the earcup cover and press it back into place. Ensure all clips and seams are securely fastened and aligned.
    • Test the headphones to ensure the new battery is functioning correctly.
Abschluss
After following these steps, your JBL Tune 710BT headphones should have a new lease on life with a fresh battery. Proper reassembly ensures the longevity and optimal performance of your headphones.
Additional Tips:
  • Handle all electronic components with care to avoid static discharge or damage.
  • Ensure the replacement battery is the correct model and specification for the JBL Tune 710BT headphones.
  • Dispose of the old battery properly, following local regulations for battery recycling.
By completing this guide, users can extend the lifespan of their JBL Tune 710BT headphones and enjoy uninterrupted listening experiences.
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 2-1, Konn Spring 2024 Mitglied von UMass Dartmouth, Team 2-1, Konn Spring 2024
UMASSD-KONN-S24S2G1
4 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 20
Insgesamt: 54
