Zum Hauptinhalt wechseln
JD Razor 2000 Back Wheel Replacement
Was du brauchst
    1. JD Razor 2000 Back Wheel Replacement, Unscrewing the Axle Bolt: Schritt 1, Bild 1 von 2 JD Razor 2000 Back Wheel Replacement, Unscrewing the Axle Bolt: Schritt 1, Bild 2 von 2
      • Facing the wheelie bar as shown, place your left thumb on the bolt located on the left side of the back wheel and place the Allen wrench into the screw on the right side of the back wheel.
      • Using the wrench, slowly unscrew the bolt while applying constant pressure from the left side.
      Frag FixBot
      Kommentar hinzufügen
    2. JD Razor 2000 Back Wheel Replacement, Removing the Bolt and Bearing: Schritt 2, Bild 1 von 2 JD Razor 2000 Back Wheel Replacement, Removing the Bolt and Bearing: Schritt 2, Bild 2 von 2
      • Remove the bolt from the right side and the bearing from the left.
      Frag FixBot
    3. JD Razor 2000 Back Wheel Replacement, Removing the Wheel: Schritt 3, Bild 1 von 1
      • Turn the JD Razor 2000 on its side as shown. Slowly remove the back wheel by pulling it out at a perpendicular angle to the scooter base.
      Frag FixBot
Abschluss
Cal Poly, Team 4-46, Amido Fall 2014 Mitglied von Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 42
Insgesamt: 1,355
