Einleitung
The fastening button on the each of the Razor's handlebars lock the handle securely with the T-Bar. This guide will show you how to remove/replace this fastening button.
Was du brauchst
Firmly hold the handle bar in place.
Grab with one hand the black removable tip of the handle bar and pull it out.
Pull out the end of the tied string through the removable tip.
Press down firmly on the golden fastening button located on the handle bar being replaced.
While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
Press strongly down on the golden fastening button located on the loose handle bar.
Tilt the opening of the handle towards you.
Reach in carefully with the small needle-nose pliers and firmly grab the golden fastening button.
Once grasping the golden fastening button tightly with small needle-nosed pliers, carefully and slowly pull it out of the handle bar.
Eine weitere Person hat diese Anleitung absolviert.
