Zum Hauptinhalt wechseln
JD Razor 2000 Front Wheel Replacement
Was du brauchst
  1. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: Schritt 1, Bild 1 von 3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: Schritt 1, Bild 2 von 3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: Schritt 1, Bild 3 von 3
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
  2. JD Razor 2000 Front Wheel Replacement, Removing the Wheel: Schritt 2, Bild 1 von 1
    • Grip the bottom of the wheel and gently slide it out.
Abschluss
Cal Poly, Team 4-46, Amido Fall 2014 Mitglied von Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 1,131
