Zum Hauptinhalt wechseln
JVC GR-D72U Lateral Function Port Panel Replacement
Was du brauchst
  1. JVC GR-D72U Lateral Function Port Panel Replacement, Battery: Schritt 1, Bild 1 von 2 JVC GR-D72U Lateral Function Port Panel Replacement, Battery: Schritt 1, Bild 2 von 2
    • Locate button on bottom of camera.
    • Slide button to the right.
  2. JVC GR-D72U Lateral Function Port Panel Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery towards the bottom of the camcorder while lifting battery .
  3. JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: Schritt 3, Bild 1 von 3 JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: Schritt 3, Bild 2 von 3 JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: Schritt 3, Bild 3 von 3
    • Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
    • Remove the 3.1 mm screw.
    • Remove the three 5.3 mm screws from the back of the camera.
  4. JVC GR-D72U Lateral Function Port Panel Replacement: Schritt 4, Bild 1 von 1
    • From the bottom of the camera remove the following four screws:
    • 5.3 mm
    • 3.1 mm
    • 5.1 mm
    • 3.5 mm
  5. JVC GR-D72U Lateral Function Port Panel Replacement: Schritt 5, Bild 1 von 1
    • Use the small plastic opening tool to remove the blue side cover piece.
  6. JVC GR-D72U Lateral Function Port Panel Replacement: Schritt 6, Bild 1 von 1
    • Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
    • Remove the 5.4 mm screw next to the snapshot button.
  7. JVC GR-D72U Lateral Function Port Panel Replacement: Schritt 7, Bild 1 von 1
    • Remove the 3.1 mm screw next to the USB and DV inputs.
  8. JVC GR-D72U Lateral Function Port Panel Replacement: Schritt 8, Bild 1 von 1
    • Gently pull apart both halves of the camera to reveal the inner components.
  9. JVC GR-D72U Lateral Function Port Panel Replacement: Schritt 9, Bild 1 von 3 JVC GR-D72U Lateral Function Port Panel Replacement: Schritt 9, Bild 2 von 3 JVC GR-D72U Lateral Function Port Panel Replacement: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
    • Insert the cables from the new port panel into their inputs and flip the locks to the down position.
    • It is easier to use tweezers when inserting the cable but not required.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S2-G2, Nance Fall 2017 Mitglied von USF Tampa, Team S2-G2, Nance Fall 2017
USFT-NANCE-F17S2G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 449
