Einleitung
The removal of the rear panel will allow you to access additional, serviceable components within the device.
Was du brauchst
Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
Remove the top panel.
Disconnect Video Out/Rear View Camera cable from circuit board.
Remove the Video Out/Rear View Camera cable retaining clip using after removing 0-64 x 3/16" machine screw using a Phillips #0 screwdriver.
Withdraw Video Out/Rear View Camera cable from rear panel.
Remove the five 1/64 x 3/16" machine screws from the rear panel identified in the photograph.
Remove rear panel.
