Zum Hauptinhalt wechseln
JVC XL-333 Power Button Replacement
Was du brauchst
  1. JVC XL-333 Power Button Replacement, The Power Button: Schritt 1, Bild 1 von 2 JVC XL-333 Power Button Replacement, The Power Button: Schritt 1, Bild 2 von 2
    • Using your Phillips Head Screwdriver, remove the four screws with the red markup.
    • Then, remove the three orange screws using your screwdriver.
  2. JVC XL-333 Power Button Replacement: Schritt 2, Bild 1 von 2 JVC XL-333 Power Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the two Phillips screws on both sides of the CD Player.
  3. JVC XL-333 Power Button Replacement: Schritt 3, Bild 1 von 3 JVC XL-333 Power Button Replacement: Schritt 3, Bild 2 von 3 JVC XL-333 Power Button Replacement: Schritt 3, Bild 3 von 3
    • Remove the top of the CD Player by holding each side of the roof then sliding it away from the front of the CD player.
  4. JVC XL-333 Power Button Replacement: Schritt 4, Bild 1 von 3 JVC XL-333 Power Button Replacement: Schritt 4, Bild 2 von 3 JVC XL-333 Power Button Replacement: Schritt 4, Bild 3 von 3
    • The disk reader is located above the power button.
    • Push out these tabs on both sides of the disk reader.
  5. JVC XL-333 Power Button Replacement: Schritt 5, Bild 1 von 3 JVC XL-333 Power Button Replacement: Schritt 5, Bild 2 von 3 JVC XL-333 Power Button Replacement: Schritt 5, Bild 3 von 3
    • Unscrew the four Phillips copper screws located at the four corners of the disc reader.
    • After the screws are removed, gently pull the disc reader up and out of the CD player.
  6. JVC XL-333 Power Button Replacement: Schritt 6, Bild 1 von 3 JVC XL-333 Power Button Replacement: Schritt 6, Bild 2 von 3 JVC XL-333 Power Button Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Gently pull up to remove the two bunches of wires with a green connector from the motherboard.
    • Remove the two groups of wires with a white connector by using your spudger or tweezers to pull up on the side of the connector, opposite of the wires. It may require some force
  7. JVC XL-333 Power Button Replacement: Schritt 7, Bild 1 von 3 JVC XL-333 Power Button Replacement: Schritt 7, Bild 2 von 3 JVC XL-333 Power Button Replacement: Schritt 7, Bild 3 von 3
    • These pictures offer other tricks and guidance on how to remove the wire connectors.
    • move your spudger or tweezer in an upward motion to release the wires.
  8. JVC XL-333 Power Button Replacement: Schritt 8, Bild 1 von 3 JVC XL-333 Power Button Replacement: Schritt 8, Bild 2 von 3 JVC XL-333 Power Button Replacement: Schritt 8, Bild 3 von 3
    • Remove the rest of the wires connecting the motherboard to the CD player with your spudger or tweezers.
    • Remove the screw that connects the wire to the motherboard.
  9. JVC XL-333 Power Button Replacement: Schritt 9, Bild 1 von 3 JVC XL-333 Power Button Replacement: Schritt 9, Bild 2 von 3 JVC XL-333 Power Button Replacement: Schritt 9, Bild 3 von 3
    • Find the power button trigger on the left side of the CD Player. It should be gray.
    • Push it a couple times to make sure it works. If not hold it 3/4 of the way and pull with some force.
    • Replace with a new one.
    • Replace the motherboard, reattach the cables and repeat the rest of the previous tasks in reverse.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 874
