Zum Hauptinhalt wechseln
Jabra CRUISER2 Motherboard Replacement
Was du brauchst
  1. Jabra CRUISER2 Motherboard Replacement, Front Plate: Schritt 1, Bild 1 von 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • iOpener Anleitung
  2. Jabra CRUISER2 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 Jabra CRUISER2 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the motherboard from the device by lifting it up from the back plate.
Abschluss
Spartacus
636 Reputation
5 Anleitungen geschrieben
Baylor, Team 8-13, Williams Fall 2014 Mitglied von Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 789
