Einleitung
If you are having problems connecting to your Jabra Elite 85H headphones there could be a problem with the Bluetooth module. Follow this guide to correctly disassemble the headsets and repair the module. This guide takes you step by step on how to do it.
Was du brauchst
Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
Tilt the headphones over so that the speaker tilts out of the plastic holder.
Repeat for both sides.
Remove the two attached circuit boards from the headphone housing.
De-solder Bluetooth Module from control board to replace.
