Zum Hauptinhalt wechseln
Jabra Elite 85h Bluetooth Module Replacement
Was du brauchst
  1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: Schritt 1, Bild 1 von 3 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: Schritt 1, Bild 2 von 3 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: Schritt 1, Bild 3 von 3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Bluetooth Module Replacement: Schritt 2, Bild 1 von 3 Jabra Elite 85h Bluetooth Module Replacement: Schritt 2, Bild 2 von 3 Jabra Elite 85h Bluetooth Module Replacement: Schritt 2, Bild 3 von 3
    • The foam inserts and backing tape are very delicate, take your time when removing them and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Bluetooth Module Replacement: Schritt 3, Bild 1 von 3 Jabra Elite 85h Bluetooth Module Replacement: Schritt 3, Bild 2 von 3 Jabra Elite 85h Bluetooth Module Replacement: Schritt 3, Bild 3 von 3
    • Repeat previous steps on other side.
  4. Jabra Elite 85h Bluetooth Module Replacement: Schritt 4, Bild 1 von 1
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Bluetooth Module Replacement: Schritt 5, Bild 1 von 1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
  6. Jabra Elite 85h Bluetooth Module Replacement: Schritt 6, Bild 1 von 2 Jabra Elite 85h Bluetooth Module Replacement: Schritt 6, Bild 2 von 2
    • Remove the two screws holding the upper and lower circuit boards in place.
  7. Jabra Elite 85h Bluetooth Module Replacement: Schritt 7, Bild 1 von 2 Jabra Elite 85h Bluetooth Module Replacement: Schritt 7, Bild 2 von 2
    • Remove the two attached circuit boards from the headphone housing.
    • De-solder Bluetooth Module from control board to replace.
Abschluss
Ryan Callaghan
693 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 3-4, Petersen Spring 2023 Mitglied von UMass Dartmouth, Team 3-4, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G4
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 92
Insgesamt: 1,259
