Zum Hauptinhalt wechseln
Jabra Freeway Speaker Replacement
Was du brauchst
  1. Jabra Freeway Speaker Replacement, Front Panel: Schritt 1, Bild 1 von 3 Jabra Freeway Speaker Replacement, Front Panel: Schritt 1, Bild 2 von 3 Jabra Freeway Speaker Replacement, Front Panel: Schritt 1, Bild 3 von 3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Speaker Replacement: Schritt 2, Bild 1 von 3 Jabra Freeway Speaker Replacement: Schritt 2, Bild 2 von 3 Jabra Freeway Speaker Replacement: Schritt 2, Bild 3 von 3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Speaker Replacement: Schritt 3, Bild 1 von 3 Jabra Freeway Speaker Replacement: Schritt 3, Bild 2 von 3 Jabra Freeway Speaker Replacement: Schritt 3, Bild 3 von 3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Speaker Replacement, Speaker: Schritt 4, Bild 1 von 2 Jabra Freeway Speaker Replacement, Speaker: Schritt 4, Bild 2 von 2
    • Gently lift the speaker out of the device using the spudger.
    • The speaker is not fixed in place, and therefore very little force is necessary to remove this component.
  5. Jabra Freeway Speaker Replacement: Schritt 5, Bild 1 von 1
    • Desolder the two wires connecting to the speaker.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Alec Wilson
741 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 4-8, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-8, Catania Fall 2016
UMASSD-CATANIA-F16S4G8
2 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
This guide is missing something. It is titled Speaker Replacement not just removal. Useful information to complete the replacement of a faulty speaker would include where to find a replacement part or at least a part number to search for. Removing the speaker without replacing it with another is of little use. But thank you for your time and effort.
Jssamp - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 980
