Einleitung
This guide explains how to replace one of the 3 main speakers in the Freeway, however all 3 speakers are removed using this guide and the process is identical. Be sure the device is completely powered off before continuing.
Was du brauchst
Remove the rubber pads from the bottom of the device using the spudger.
Gently lift the front panel off of the device and carefully rest it to the side.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
This guide is missing something. It is titled Speaker Replacement not just removal. Useful information to complete the replacement of a faulty speaker would include where to find a replacement part or at least a part number to search for. Removing the speaker without replacing it with another is of little use. But thank you for your time and effort.
