Einleitung
In order to access the inner components of the Jabra Speak 510, you will need to remove the back plate and the front plate.
Was du brauchst
Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
Slowly flip the device open like a clam shell.
Fast fertig!
Abschluss
