Einleitung
Replacement of the motherboard located inside the Jam Voice will be achieved by dismantling the device. The speaker and battery must be disconnected.
Was du brauchst
Insert the plastic opening tool underneath the mesh top.
Pry the cover open.
Remove the four 5mm Phillips screws that hold down the speaker in place.
Remove the two 6mm Phillips screws that hold down the plastic casing.
Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
Pull the speaker up and out.
After removing all of the screws from the plastic cover, remove it by pulling up and out.
Remove the three 5mm Phillips screws that hold the motherboard in place.
After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
