Zum Hauptinhalt wechseln
Jam Voice Motherboard Replacement
Was du brauchst
  1. Jam Voice Motherboard  Replacement, Hard Mesh Cover: Schritt 1, Bild 1 von 2 Jam Voice Motherboard  Replacement, Hard Mesh Cover: Schritt 1, Bild 2 von 2
    • Insert the plastic opening tool underneath the mesh top.
    • Pry the cover open.
    • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
  2. Jam Voice Motherboard  Replacement, Motherboard: Schritt 2, Bild 1 von 1
    • Remove the four 7mm Phillips screws from the plastic cover.
  3. Jam Voice Motherboard  Replacement: Schritt 3, Bild 1 von 2 Jam Voice Motherboard  Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 5mm Phillips screws that hold down the speaker in place.
    • Remove the two 6mm Phillips screws that hold down the plastic casing.
  4. Jam Voice Motherboard  Replacement: Schritt 4, Bild 1 von 1
    • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
    • Pull the speaker up and out.
  5. Jam Voice Motherboard  Replacement: Schritt 5, Bild 1 von 3 Jam Voice Motherboard  Replacement: Schritt 5, Bild 2 von 3 Jam Voice Motherboard  Replacement: Schritt 5, Bild 3 von 3
    • Remove the four 7mm Phillips screws to expose the motherboard.
  6. Jam Voice Motherboard  Replacement: Schritt 6, Bild 1 von 1
    • After removing all of the screws from the plastic cover, remove it by pulling up and out.
    • Be careful not to pull and damage any of the wires.
  7. Jam Voice Motherboard  Replacement: Schritt 7, Bild 1 von 2 Jam Voice Motherboard  Replacement: Schritt 7, Bild 2 von 2
    • Remove the three 5mm Phillips screws that hold the motherboard in place.
    • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 222
