Einleitung
The rubber base may be worn and in need of replacement or to gain access to the underside of the device . Depending on objectives, a new rubber base may be applied or the used base may be reapplied.
Was du brauchst
Use the plastic opening tool to help peel the rubber cover off the base.
Peel off the rest of the rubber base by hand.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
