Was du brauchst
Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
Peel the indicated rubber tabs off, at the bottom of the speaker, using a plastic opening tool if necessary.
Unscrew indicated T6 9.7 mm screws.
Place the Jambox with the left end cap facing upward. There’s 4 screws need to take off.
With the side cap removed, pry open the bottom panel by letting up.
Pull the bottom up. This may take a bit of force as the bottom is glued to device.
Once removed, the battery is now visible.
Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
With the battery facing forward, remove the three indicated T6 9.5 mm screws.
Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
Turn the Jambox so that the button panel is visible.
Remove the indicated screws, T6 9.6 mm.
Remove the colored ribbon that connects the green button circuit board to the blue auxiliary board by using your finger to lift the small black tabs that clamp down the ribbon.
Pictures where referenced from previous guides.
2 weitere Personen haben diese Anleitung absolviert.
7 Kommentare zur Anleitung
Where can you get a replacement aux board? Or specific components on it? (My bluetooth pairing switch seems not to work, everything else seems fine.)
Donde puedo encintrar toda la parte completa para remplazarla
Como puedo comprar toda parte completa de donde entra la carga ala spearck jawbone big jambox
