Einleitung
The Jawbone MINI JAMBOX has an aluminum unibody outer shell. You must remove this outer shell in order to replace the inner components.
Was du brauchst
Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
Carefully remove the end panel.
Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
Push against the side without end cap to slide the internal components out of the case.
While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Does anyone know where to find replacement outer shells for the big jambox?
