Zum Hauptinhalt wechseln
Einleitung
This guide will aid the user in the installation of the batteries in this device. This guide is to be used if the batteries in the device die. When putting new batteries into the device, be sure that the batteries are orientated that right way as shown on the case.
  1. Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab. Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
    • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
  2. Tilt device so that batteries slide out.
    • Tilt device so that batteries slide out.
Abschluss
Katelyn Fry
1 Reputation
7 Anleitungen geschrieben
Clemson, Team 12-3, Benson Spring 2013 Mitglied von Clemson, Team 12-3, Benson Spring 2013
CLEM-BENSON-S13S12G3
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 127
