Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will aid the user in the installation of the capture button for this device. The capture button is the button that is pressed in order to take a picture. This device is to be used if for some reason the capture button breaks or is pushed into the device.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab. Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
    • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
  2. Tilt device so that batteries slide out.
    • Tilt device so that batteries slide out.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Carefully insert the flat end of the spudger into the seam on the top side of the device.  Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate. Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart.  Take care not to break the plastic hinge as the battery compartment cover is removed. Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart.  Take care not to break the plastic hinge as the battery compartment cover is removed.
    • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
    • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
  5. There are two wires (one red and one black) that could get disconnected from the motherboard when prying the case apart. Gently seperate the two halves of the device. To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
    • There are two wires (one red and one black) that could get disconnected from the motherboard when prying the case apart.
    • Gently seperate the two halves of the device.
    • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
    • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
  6. Carefully separate the grey side bar from the case and set it aside.
    • Carefully separate the grey side bar from the case and set it aside.
  7. Use the tweezers to grasp the bottom of the capture button.  Pull the capture button away from the case and set it aside.
    • Use the tweezers to grasp the bottom of the capture button. Pull the capture button away from the case and set it aside.
Abschluss
Katelyn Fry
1 Reputation
7 Anleitungen geschrieben
Clemson, Team 12-3, Benson Spring 2013 Mitglied von Clemson, Team 12-3, Benson Spring 2013
CLEM-BENSON-S13S12G3
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 119
