Zum Hauptinhalt wechseln
Jazz HDV178 Camcorder Battery Replacement
  1. Jazz HDV178 Camcorder Battery Replacement, Disassembling Jazz HDV178 Camcorder Take off Back Cover: Schritt 1, Bild 1 von 1
    • On the back of the camcorder, the side opposite of the flip-out screen, there is a section of grooved plastic with a small arrow.
    • Press down on the grooved plastic with your thumbs.
    • Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
  2. Jazz HDV178 Camcorder Battery Replacement, Battery: Schritt 2, Bild 1 von 1
    • Once you have the back cover off, the camcorder should look like this.
    • Look on the battery for a model number to assure that you acquire the correct replacement part.
    • The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
  3. Jazz HDV178 Camcorder Battery Replacement: Schritt 3, Bild 1 von 1
    • Take the battery out by pulling up on the bottom of the battery. You should be pulling from the side of the camera where the wrist strap is attached.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
timothy
354 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 7-34, Regan Winter 2011 Mitglied von Cal Poly, Team 7-34, Regan Winter 2011
CPSU-REGAN-W11S7G34
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 7
Insgesamt: 3,143
