Zum Hauptinhalt wechseln
Jazz UltraTab C1059-HL Antenna Replacement
Was du brauchst
  1. Jazz UltraTab C1059-HL Antenna Replacement, Antenna: Schritt 1, Bild 1 von 1
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Antenna Replacement: Schritt 2, Bild 1 von 1
    • Remove the back panel of the device.
  3. Jazz UltraTab C1059-HL Antenna Replacement: Schritt 3, Bild 1 von 1
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Antenna Replacement: Schritt 4, Bild 1 von 1
    • Identify the antenna cover on the top of the device.
  5. Jazz UltraTab C1059-HL Antenna Replacement: Schritt 5, Bild 1 von 1
    • Remove the two screws holding the antenna cover in place.
  6. Jazz UltraTab C1059-HL Antenna Replacement: Schritt 6, Bild 1 von 1
    • Use a prying tool to remove the plastic piece off of the antenna component.
  7. Jazz UltraTab C1059-HL Antenna Replacement: Schritt 7, Bild 1 von 1
    • Identify the antenna component as the gray cable that comes out of the plastic cover.
  8. Jazz UltraTab C1059-HL Antenna Replacement: Schritt 8, Bild 1 von 1
    • Remove all of the adhesive tape pieces off of the antenna cable.
  9. Jazz UltraTab C1059-HL Antenna Replacement: Schritt 9, Bild 1 von 1
    • Once all of the adhesive tape has been removed. Pull out the antenna component.
  10. Jazz UltraTab C1059-HL Antenna Replacement: Schritt 10, Bild 1 von 1
    • The antenna will be attached to the chip in your device. Be careful not to pull off.
    • Solder of the wire that is connected to the chip in order to be able to remove the antenna component.
    • Once this is done, you can replace your old antenna with a new one!
Abschluss
IUPUI, Team 1-3, Wilson Fall 2015 Mitglied von IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 191
