Einleitung
This guide will guide the user to effectively remove and replace the antenna. This replacement will take 20-30 minutes. However, if the guide is followed to the letter, the task will be accomplished with minimal damage to the device.
Was du brauchst
Identify the antenna component as the gray cable that comes out of the plastic cover.
Once all of the adhesive tape has been removed. Pull out the antenna component.
The antenna will be attached to the chip in your device. Be careful not to pull off.
Solder of the wire that is connected to the chip in order to be able to remove the antenna component.
Once this is done, you can replace your old antenna with a new one!
