Zum Hauptinhalt wechseln
Jazz UltraTab C1059-HL Battery Replacement
Was du brauchst
  1. Jazz UltraTab C1059-HL Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • remove the screws at the four corners of the device.
  2. Jazz UltraTab C1059-HL Battery Replacement: Schritt 2, Bild 1 von 2 Jazz UltraTab C1059-HL Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a prying tool to pry the back panel from the tablet chassis. Pry the panel at different locations around the device to separate clips.
  3. Jazz UltraTab C1059-HL Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a soldering iron to remove power cables from battery. The power cable is shown at the corner of the battery in the picture.
  4. Jazz UltraTab C1059-HL Battery Replacement: Schritt 4, Bild 1 von 2 Jazz UltraTab C1059-HL Battery Replacement: Schritt 4, Bild 2 von 2
    • Use a tool to carefully pry battery away from chassis. The battery is attached by an adhesive. Slowly pry battery on the side away from the motherboard.
  5. Jazz UltraTab C1059-HL Battery Replacement: Schritt 5, Bild 1 von 1
    • You have successfully removed the battery. Put new battery in the same location. Solder the supply wires. Reapply tape in original location.
Abschluss
IUPUI, Team 1-3, Wilson Fall 2015 Mitglied von IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 592
