Zum Hauptinhalt wechseln
Jazz UltraTab C1059-HL Screen Replacement
Was du brauchst
  1. Jazz UltraTab C1059-HL Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the back panel of the device.
    • Be careful not to brake/bend the plastic cover of your device.
  3. Jazz UltraTab C1059-HL Screen Replacement: Schritt 3, Bild 1 von 1
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove all data strips attached to the motherboard.
  5. Jazz UltraTab C1059-HL Screen Replacement: Schritt 5, Bild 1 von 3 Jazz UltraTab C1059-HL Screen Replacement: Schritt 5, Bild 2 von 3 Jazz UltraTab C1059-HL Screen Replacement: Schritt 5, Bild 3 von 3
    • Remove the tape around the battery.
    • One of these pieces of tape holds down the battery connection to the mainboard.
    • Use the soldering iron to disconnect these wires.
    • You will need to use a tool to pry off the battery. It will have a good amount of adhesive holding it down.
    • Be cautious not to bend the battery when prying.
  6. Jazz UltraTab C1059-HL Screen Replacement: Schritt 6, Bild 1 von 1
    • Once the battery is removed, make sure to remove any and all data strips that are attached.
    • Then begin to unscrew the mother board.
  7. Jazz UltraTab C1059-HL Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the motherboard chip off of the device.
  8. Jazz UltraTab C1059-HL Screen Replacement: Schritt 8, Bild 1 von 1
    • Your board should look like this after taking all of the components off the screen panel.
  9. Jazz UltraTab C1059-HL Screen Replacement: Schritt 9, Bild 1 von 2 Jazz UltraTab C1059-HL Screen Replacement: Schritt 9, Bild 2 von 2
    • Remove the Display Module from the screen cover.
  10. Jazz UltraTab C1059-HL Screen Replacement: Schritt 10, Bild 1 von 1
    • Now, you can replace your broken or damaged screen!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team 1-3, Wilson Fall 2015 Mitglied von IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 445
