Einleitung
This guide will guide the user to effectively remove and replace the speaker. This replacement will take around 15-20 minutes. However, if the guide is followed to the letter, the task will be accomplished with minimal damage to the device.
Was du brauchst
Start by removing the back panel.
Remove the 4 screws holding the device together: two on the left side, and two on the right side.
Using a metal spudger, carefully pry open the case.
Using a soldering iron, heat up the spot where the speaker wires connect to the mainboard.
Remove Speaker wires when the solder liquifies.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
