Einleitung
Don't dump your device simply because the camera isn't working! This guide will help you easily replace the faulty camera on your tablet.
Was du brauchst
Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
Using a plastic opening tool, lift open the tab that holds the connection between the camera and motherboard in place. The ribbon cable will become detached.
Finally, detach the camera lenses from the cover by gently pulling them away from the case.
