Zum Hauptinhalt wechseln
Jean Zipper Repair
Was du brauchst
  1. Jean Zipper Repair, Jean Zipper Repair: Schritt 1, Bild 1 von 3 Jean Zipper Repair, Jean Zipper Repair: Schritt 1, Bild 2 von 3 Jean Zipper Repair, Jean Zipper Repair: Schritt 1, Bild 3 von 3
    • Place your zipper in the upright position before trying to connect it to the zipper tracks.
    • If one of the zipper sides can be attached back on the tracks without any help, SKIP to Step 3.
    • If your zipper cannot be attached to the tracks easily, continue to the next step.
  2. Jean Zipper Repair: Schritt 2, Bild 1 von 3 Jean Zipper Repair: Schritt 2, Bild 2 von 3 Jean Zipper Repair: Schritt 2, Bild 3 von 3
    • Use the flathead screwdriver and place it in between the zipper sides.
    • Twist the flathead screwdriver back and forth while holding the zipper steady.
    • This will allow the zipper side to open wider so the zipper tracks can fit in between the zipper's sides.
  3. Jean Zipper Repair: Schritt 3, Bild 1 von 3 Jean Zipper Repair: Schritt 3, Bild 2 von 3 Jean Zipper Repair: Schritt 3, Bild 3 von 3
    • Attach the zipper to the zipper tracks.
    • Use the hammer to help close the zipper side onto the track.
    • Be sure to check that the zipper is secure on the track. Do this by moving the zipper up and down on the track and tugging on the zipper.
  4. Jean Zipper Repair: Schritt 4, Bild 1 von 2 Jean Zipper Repair: Schritt 4, Bild 2 von 2
    • Repeat Step 2 for the other side of the zipper.
  5. Jean Zipper Repair: Schritt 5, Bild 1 von 1
    • Make sure the tracks are even before hammering down the second side.
    • Pull and tug on the zipper and jeans until the tracks start lining up.
  6. Jean Zipper Repair: Schritt 6, Bild 1 von 3 Jean Zipper Repair: Schritt 6, Bild 2 von 3 Jean Zipper Repair: Schritt 6, Bild 3 von 3
    • Start hammering the top and sides of the zipper to secure the closing.
    • Check to make sure the zipper is attached by moving the zipper up and down.
    • Continue to hammer the top and sides if the tracks aren't connecting when you zip up the jeans.
  7. Jean Zipper Repair: Schritt 7, Bild 1 von 3 Jean Zipper Repair: Schritt 7, Bild 2 von 3 Jean Zipper Repair: Schritt 7, Bild 3 von 3
    • After hammering the zipper, everything should be secure. Move the zipper up and down a few more times to ensure the tracks are even, connecting and staying connected.
Abschluss
Follow these quick 30 minute instructions to save your jeans.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Nadia Simpson
394 Reputation
2 Anleitungen geschrieben
University of Memphis, Team 50-20, Willis Fall 2021 Mitglied von University of Memphis, Team 50-20, Willis Fall 2021
UM-WILLIS-F21S50G20
1 Mitglied
Ein Kommentar
Thanks for the article that helped me gain more knowledge to fix the zipper of my pants. Now I'm going to pull out my broken pants and practice.
Theresa Almanza - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 25
Letzte 30 Tage: 142
Insgesamt: 9,995
