Einleitung
Welcome to the guide that’s designed to help you keep your favorite pair of jeans with a working zipper. As time goes by those favorite pair of jeans tend to loosen up in some areas, the zipper being one of those areas. This guide will help you save money using these very easy steps. Follow this guide if you need to repair the zipper on your jeans.
Was du brauchst
Place your zipper in the upright position before trying to connect it to the zipper tracks.
If one of the zipper sides can be attached back on the tracks without any help, SKIP to Step 3.
If your zipper cannot be attached to the tracks easily, continue to the next step.
Use the flathead screwdriver and place it in between the zipper sides.
Twist the flathead screwdriver back and forth while holding the zipper steady.
This will allow the zipper side to open wider so the zipper tracks can fit in between the zipper's sides.
Attach the zipper to the zipper tracks.
Use the hammer to help close the zipper side onto the track.
Be sure to check that the zipper is secure on the track. Do this by moving the zipper up and down on the track and tugging on the zipper.
Make sure the tracks are even before hammering down the second side.
Pull and tug on the zipper and jeans until the tracks start lining up.
Start hammering the top and sides of the zipper to secure the closing.
Check to make sure the zipper is attached by moving the zipper up and down.
Continue to hammer the top and sides if the tracks aren't connecting when you zip up the jeans.
After hammering the zipper, everything should be secure. Move the zipper up and down a few more times to ensure the tracks are even, connecting and staying connected.
Follow these quick 30 minute instructions to save your jeans.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Thanks for the article that helped me gain more knowledge to fix the zipper of my pants. Now I'm going to pull out my broken pants and practice.
