Einleitung
This is a simple repair of adding a two-hole button onto a pair of jeans. This repair requires a needle, thread, fabric scissors, and a fabric marker. After following the steps in this guide, a two-hole button should be firmly attached to a pair of jeans. Keep in mind that the needle being used in sharp and is hard to spot if dropped.
Is a two-hole button just not looking how you’d like? Here is a link to re-attach a four-hole button! Einen Knopf annähen
Was du brauchst
Find a thread color that matches the fabric you are sewing the button on to.
Loop the thread through the eye of the needle.
Tie a small knot around the eye of the needle with the thread.
Thread the needle through the fabric from the inside out.
Tie a knot at the end of the thread after pulling most of it through the fabric.
Place the button over the small stitched 'x' or fabric marker spot.
Thread the needle through the left hole of the button from the inside out.
Pull the needle and thread all the way through the fabric.
Cross the needle over to the right hole of the button.
Thread the needle all the way through the fabric.
Create a thread shank on the inside of the fabric by looping the thread around a stitch.
Pull the thread all the way through the hole until it is tight.
Tie a knot after the final stitch to secure the stitches.
After cutting the remaining thread, your button stays on your jeans.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
