Einleitung
This guide will explain how to resolder the electric motor wire placed inside a CD player. Resoldering the wire increases the chance of spinning the CD stuck inside the player.
Was du brauchst
Upturn the CD player and take out the batteries.
To take out the batteries, pull back and lift the battery cover.
Flip the CD player back and open the lid. You will see two 10 mm Phillips screws on the left and right side under the lid.
To open the lid, push the button on the far right with an ejection symbol. Once the button is pushed, carefully lift the lid.
Unscrew each 10 mm Phillips screw with the screwdriver, and place them outside safely.
Turn the CD player upside down and open the battery compartment. You will see one more 10 mm Phillips screw inside. Unscrew it.
Use the Phillips screwdriver to remove the screw. Place the screw outside safely.
Locate the motor on the bottom portion of the CD player. Lift the motor up and turn it over.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
