Zum Hauptinhalt wechseln
Jensen JTA-230 Speaker Replacement
Was du brauchst
    • First, open the dust cover and grab it by the hinges and pull up until it slides out.
    • Then, using a screwdriver unscrew the 3 screws on each side and remove the top layer of the record player. The top should pop out.
  1. Jensen JTA-230 Speaker Replacement: Schritt 2, Bild 1 von 2 Jensen JTA-230 Speaker Replacement: Schritt 2, Bild 2 von 2
    • You should see the speakers(one on both side). From here, you want to unscrew the three screws holding them in place, using the same head as the previous step.
  2. Jensen JTA-230 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the speakers from the device, being careful not to harm any components of the speaker.
  3. Jensen JTA-230 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Once the speaker is out of the device, you should use a soldering iron to take off the wires on the current broken speaker, and put them to the new speaker using a soldering iron.
Abschluss
John Roche
175 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 8-8, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-8, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G8
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
What type of speakers do I need to buy?
Isaac Bott - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 579
