Was du brauchst
Remove the 4 rubber plugs which hold the turntable platter in place
Gently but firmly pull the turntable platter off the axle.
Ein Kommentar
There's an important step missing here in that there is a "C" clip on the center pin that you need to remove. Also, this does not include how to replace the belt onto the motor, which is vital in restoring how a record player functions. Can you please update with this information?
