Zum Hauptinhalt wechseln
Joy-Con Motherboard Replacement
Was du brauchst
  1. Joy-Con Motherboard Replacement, Find Y00 screws: Schritt 1, Bild 1 von 1
    • I'm going to use left Joy-Con, but it doesn't matter which Joy-Con
  2. Joy-Con Motherboard Replacement, Unscrewing: Schritt 2, Bild 1 von 1
    • Take your Y00 screwdriver and get to work! Unscrew the screws
  3. Joy-Con Motherboard Replacement, Opening: Schritt 3, Bild 1 von 1
    • Carefully open the Joy-Con backshell, take your time!
    • Note: It has wires attached, BE CAREFUL!
  4. Joy-Con Motherboard Replacement, Unscrewing backshell: Schritt 4, Bild 1 von 1
    • Backshell can get really annoying, so why won't we just unscrew it? Take 00 screwdriver and let's get it done!
    • Note: DO NOT unscrew bolts on an LED strip.
Abschluss
Savalio AnanaNIMus
37 Reputation
1 Anleitung geschrieben
Ein Kommentar
This guide only stops at removing the outer screws and doesn't show the fill process. Please update.
Shannon W - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 4
Letzten 7 Tage: 61
Letzten 30 Tage: 270
Insgesamt: 551
