Zum Hauptinhalt wechseln
Jumper Angelsounds JPD-100S The Transducer Replacement
Was du brauchst
  1. Jumper Angelsounds JPD-100S The Transducer  Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 2, Bild 1 von 2 Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 2, Bild 2 von 2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 3, Bild 1 von 1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 4, Bild 1 von 2 Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 4, Bild 2 von 2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 5, Bild 1 von 2 Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 5, Bild 2 von 2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 6, Bild 1 von 1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 7, Bild 1 von 1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S The Transducer  Replacement, The Transducer: Schritt 8, Bild 1 von 1
    • Unsolder the Black cable
  9. Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 9, Bild 1 von 2 Jumper Angelsounds JPD-100S The Transducer  Replacement: Schritt 9, Bild 2 von 2
    • Unsolder the red cables from the metal plates.
Abschluss
Muosa Almubarak
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team 6-1, Remmell Fall 2015 Mitglied von USF Tampa, Team 6-1, Remmell Fall 2015
USFT-REMMELL-F15S6G1
6 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 359
