Zum Hauptinhalt wechseln
Jumper EZBook Touchpad Replacement
Was du brauchst
  1. Jumper EZBook Touchpad Replacement, Touchpad: Schritt 1, Bild 1 von 2 Jumper EZBook Touchpad Replacement, Touchpad: Schritt 1, Bild 2 von 2
    • Place the laptop so the bottom is facing upwards.
    • Remove the two 8 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the three 5 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the six 4 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the single 3 mm base screw inside the battery case using a T3 Torx screwdriver.
  2. Jumper EZBook Touchpad Replacement: Schritt 2, Bild 1 von 3 Jumper EZBook Touchpad Replacement: Schritt 2, Bild 2 von 3 Jumper EZBook Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Detach the battery case using the flat end of a spudger.
  3. Jumper EZBook Touchpad Replacement: Schritt 3, Bild 1 von 3 Jumper EZBook Touchpad Replacement: Schritt 3, Bild 2 von 3 Jumper EZBook Touchpad Replacement: Schritt 3, Bild 3 von 3
    • Pry apart the bottom cover of the laptop using the flat end of a spudger.
  4. Jumper EZBook Touchpad Replacement: Schritt 4, Bild 1 von 3 Jumper EZBook Touchpad Replacement: Schritt 4, Bild 2 von 3 Jumper EZBook Touchpad Replacement: Schritt 4, Bild 3 von 3
    • Remove the four 4 mm screws from the battery using a T3 Torx screwdriver.
  5. Jumper EZBook Touchpad Replacement: Schritt 5, Bild 1 von 3 Jumper EZBook Touchpad Replacement: Schritt 5, Bild 2 von 3 Jumper EZBook Touchpad Replacement: Schritt 5, Bild 3 von 3
    • Flip the battery to the opposite side of the touchpad.
  6. Jumper EZBook Touchpad Replacement: Schritt 6, Bild 1 von 3 Jumper EZBook Touchpad Replacement: Schritt 6, Bild 2 von 3 Jumper EZBook Touchpad Replacement: Schritt 6, Bild 3 von 3
    • Detach the tape on the left side of the touchpad shown in the first two images.
    • Use a heat gun or a hair dryer to melt the glue quickly.
  7. Jumper EZBook Touchpad Replacement: Schritt 7, Bild 1 von 3 Jumper EZBook Touchpad Replacement: Schritt 7, Bild 2 von 3 Jumper EZBook Touchpad Replacement: Schritt 7, Bild 3 von 3
    • Detach the tape on the right side of the touchpad shown in all three images.
    • Use a hair dryer or a heat gun to soften the glue.
  8. Jumper EZBook Touchpad Replacement: Schritt 8, Bild 1 von 3 Jumper EZBook Touchpad Replacement: Schritt 8, Bild 2 von 3 Jumper EZBook Touchpad Replacement: Schritt 8, Bild 3 von 3
    • Use a spudger to detach the touchpad from the top case.
    • The touchpad is attached to the top case with glue. Use a hair dryer or a heat gun to soften the glue.
    • Be patient. Step 8 can take up to 8 hours if you work by yourself.
    • Don't aim the heat gun or the hair dryer anywhere other than the top case.
  9. Jumper EZBook Touchpad Replacement: Schritt 9, Bild 1 von 3 Jumper EZBook Touchpad Replacement: Schritt 9, Bild 2 von 3 Jumper EZBook Touchpad Replacement: Schritt 9, Bild 3 von 3
    • Lift the touchpad out of the case.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Zed Chen
223 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 2-10, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 2-10, Briggs Fall 2022
CSULA-BRIGGS-F22S2G10
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 69
Insgesamt: 903
