Zum Hauptinhalt wechseln
Jura Drainage valve (2)
Was du brauchst
  1. Jura Drainage valve (2), Jura Drainage valve (2): Schritt 1, Bild 1 von 3 Jura Drainage valve (2), Jura Drainage valve (2): Schritt 1, Bild 2 von 3 Jura Drainage valve (2), Jura Drainage valve (2): Schritt 1, Bild 3 von 3
    • The brewing group has already been removed and disassembled. Now it's time for the drainage valve.
    • There will be many pictures
    • All you need a small flathead screwdriver.
  2. Jura Drainage valve (2): Schritt 2, Bild 1 von 3 Jura Drainage valve (2): Schritt 2, Bild 2 von 3 Jura Drainage valve (2): Schritt 2, Bild 3 von 3
    • Images front and back
  3. Jura Drainage valve (2): Schritt 3, Bild 1 von 3 Jura Drainage valve (2): Schritt 3, Bild 2 von 3 Jura Drainage valve (2): Schritt 3, Bild 3 von 3
    • Pull off the clamp and pull out the inlet hose. At the end there is a seal, it often gets stuck in the drainage valve. Swap them out when reassembling.
  4. Jura Drainage valve (2): Schritt 4, Bild 1 von 3 Jura Drainage valve (2): Schritt 4, Bild 2 von 3 Jura Drainage valve (2): Schritt 4, Bild 3 von 3
    • Pull out the clip on the docking tube
    • Pry out the valve body. Make sure the white cap slides out of its hole.
    • Detach the docking nozzle.
  5. Jura Drainage valve (2): Schritt 5, Bild 1 von 3 Jura Drainage valve (2): Schritt 5, Bild 2 von 3 Jura Drainage valve (2): Schritt 5, Bild 3 von 3
    • Detailed photos.
    • The position of the sealing rings are marked green in picture 3.
    • The sealing ring on the docking socket is marked in red in picture 2. It is especially important. It's a little thinner than the other two.
    • The brackets are marked in red.
  6. Jura Drainage valve (2): Schritt 6, Bild 1 von 3 Jura Drainage valve (2): Schritt 6, Bild 2 von 3 Jura Drainage valve (2): Schritt 6, Bild 3 von 3
    • Here all the parts of the valve.
  7. Jura Drainage valve (2): Schritt 7, Bild 1 von 1
    • Here is the entire valve in one picture
  8. Jura Drainage valve (2): Schritt 8, Bild 1 von 3 Jura Drainage valve (2): Schritt 8, Bild 2 von 3 Jura Drainage valve (2): Schritt 8, Bild 3 von 3
    • Reassembly
    • When assembling, make sure that the lips of the seals point to the pressure side, i.e. inward, and the flat side outward.
    • When installing, make sure that the pressure hose runs through the slot in the valve carrier.
Abschluss
Follow the steps in reverse order to reassemble your device.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
de en
100%
Hier starten ›
Schwarzstein
2.813 Reputation
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 32
Letzte 30 Tage: 209
Insgesamt: 7,949
