Einleitung
Like many push mowers, the K-Gro Power Pro has reliability issues with the motor cable and tends to become brittle over time. This guide is a step-by-step plan, on how to replace the motor cable for this mower so that you can continue to operate your mower without having to buy a brand new one.
Was du brauchst
Locate the throttle assembly on your mower on the right side of the push bar.
The throttle assembly is attached to the push bar with a 7/16" bolt and nut.
Using a 3/8" drive rachet wrench with a 7/16" socket and a 7/16" combination wrench, remove the nut.
Pull the plastic cable connection away from the framework.
Pull the cable towards the handle to allow the wire to become loose. This will give you enough room to remove the hook.
Following the cable down to the engine, you see that a zip tie holds the cable to the main handle.
Use a box cutter, sharp pocket knife, or cutting pliers to cut the zip tie.
Locate the plastic fitting hooked to the steel housing of the engine.
To the left of the fitting, you will see a steel sliding mechanism connected by a spring.
Squeeze the mechanism together to allow for slack in the cable wire.
On close inspection of the plastic fitting, you can see that there are two "wings" that can be pinched together.
With the sliding mechanism squeezed and the wire slack, pinch the plastic wings together and push the fitting to the right out of the hole in the housing.
The loose wire can then be slid up through the groove in the steel.
You can see that the only thing still holding the cable on is a hook attached to a spring loaded lever.
Remove the hook.
Eine weitere Person hat diese Anleitung absolviert.
