Zum Hauptinhalt wechseln
K5 Desktop Humidifier Cotton Swab Filter Replacement
Was du brauchst
  1. K5 Desktop Humidifier Cotton Swab Filter Replacement, Cotton Swab Filter: Schritt 1, Bild 1 von 1
    • Press and hold the humidifier switch. Check whether the connection to the power supply still works.
    • The purpose is to rule out a power failure that would render the humidifier inoperable.
  2. K5 Desktop Humidifier Cotton Swab Filter Replacement: Schritt 2, Bild 1 von 1
    • Use the spudger to slowly pry the middle part of the humidifier at the seam.
    • Be slow to open it, otherwise the humidifier outer body could be damaged.
  3. K5 Desktop Humidifier Cotton Swab Filter Replacement: Schritt 3, Bild 1 von 3 K5 Desktop Humidifier Cotton Swab Filter Replacement: Schritt 3, Bild 2 von 3 K5 Desktop Humidifier Cotton Swab Filter Replacement: Schritt 3, Bild 3 von 3
    • Remove the cotton swab and spring from inside the humidifier.
  4. K5 Desktop Humidifier Cotton Swab Filter Replacement: Schritt 4, Bild 1 von 1
    • Replace the old cotton swab filter with the new cotton swab.
  5. K5 Desktop Humidifier Cotton Swab Filter Replacement: Schritt 5, Bild 1 von 3 K5 Desktop Humidifier Cotton Swab Filter Replacement: Schritt 5, Bild 2 von 3 K5 Desktop Humidifier Cotton Swab Filter Replacement: Schritt 5, Bild 3 von 3
    • Put the new cotton swab into the humidifier.
    • Hand tighten the part where the cotton swab and humidifier meet.
    • The picture shows how it looks when fully installed.
  6. K5 Desktop Humidifier Cotton Swab Filter Replacement: Schritt 6, Bild 1 von 1
    • Reassemble the humidifier by snapping on the top half.
  7. K5 Desktop Humidifier Cotton Swab Filter Replacement: Schritt 7, Bild 1 von 1
    • Plug in the power adaptor to your USB port to use.
Abschluss
YikunFang
169 Reputation
1 Anleitung geschrieben
York University, Team R-10, Melo-Thaiss Winter 2022 Mitglied von York University, Team R-10, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG10
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 47
Insgesamt: 1,523
