Einleitung
These instructions will demonstrate how to remove the front LCD screen from the KDDI Kyocera A5521K.
  1. Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone. Beneath the covers are screws. Beneath the covers are screws.
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  2. Remove the screws using a Y0 screwdriver.
    • Remove the screws using a Y0 screwdriver.
  3. Use the iPod pry tool to remove the outer screen. Two screws are now visible. Be careful not to crack the screen upon removal.  It is adhered strongly to the phone.
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Use the Y0 screwdriver to remove the screws.
    • Use the Y0 screwdriver to remove the screws.
  6. Use the iPod pry tool to loosen the faceplate from the phone. Slide the pry tool along the entire crease of the faceplate to completely detach it.
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  7. Separate the faceplate from the phone. Separate the faceplate from the phone. Separate the faceplate from the phone.
    • Separate the faceplate from the phone.
  8. Rotate the phone 180 degrees. Grab the flexible circuit with tweezers (or use your fingers if you can manage a firm grip). Pull the flexible circuit to towards you to separate the front LCD screen from the phone.
    • Rotate the phone 180 degrees.
    • Grab the flexible circuit with tweezers (or use your fingers if you can manage a firm grip).
    • Pull the flexible circuit to towards you to separate the front LCD screen from the phone.
  9. Firmly pull the flexible circuit from the connector. Be careful not to damage the flexible circuit. The front LCD screen should now be separate from the phone.
    • Firmly pull the flexible circuit from the connector.
    • Be careful not to damage the flexible circuit.
    • The front LCD screen should now be separate from the phone.
Abschluss
Dominic Grisafe
157 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 28-25, Regan Spring 2010 Mitglied von Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Mitglieder
20 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,270
