Zum Hauptinhalt wechseln
KDDI Kyocera A5521K Speaker Replacement
Was du brauchst
  1. KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: Schritt 1, Bild 1 von 3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: Schritt 1, Bild 2 von 3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: Schritt 1, Bild 3 von 3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. KDDI Kyocera A5521K Speaker Replacement: Schritt 2, Bild 1 von 3 KDDI Kyocera A5521K Speaker Replacement: Schritt 2, Bild 2 von 3 KDDI Kyocera A5521K Speaker Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: Schritt 3, Bild 1 von 3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: Schritt 3, Bild 2 von 3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: Schritt 3, Bild 3 von 3
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. KDDI Kyocera A5521K Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the screws using a Y0 screwdriver.
  5. KDDI Kyocera A5521K Speaker Replacement: Schritt 5, Bild 1 von 3 KDDI Kyocera A5521K Speaker Replacement: Schritt 5, Bild 2 von 3 KDDI Kyocera A5521K Speaker Replacement: Schritt 5, Bild 3 von 3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  6. KDDI Kyocera A5521K Speaker Replacement: Schritt 6, Bild 1 von 1
    • Use the Y0 screwdriver to remove the screws.
  7. KDDI Kyocera A5521K Speaker Replacement: Schritt 7, Bild 1 von 2 KDDI Kyocera A5521K Speaker Replacement: Schritt 7, Bild 2 von 2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  8. KDDI Kyocera A5521K Speaker Replacement: Schritt 8, Bild 1 von 3 KDDI Kyocera A5521K Speaker Replacement: Schritt 8, Bild 2 von 3 KDDI Kyocera A5521K Speaker Replacement: Schritt 8, Bild 3 von 3
    • Separate the faceplate from the phone.
  9. KDDI Kyocera A5521K Speaker Replacement, Speaker: Schritt 9, Bild 1 von 2 KDDI Kyocera A5521K Speaker Replacement, Speaker: Schritt 9, Bild 2 von 2
    • Turn the phone over.
    • Place a spudger in the oval shaped speaker opening of the phone (indicated by the red rectangle).
    • Turn the phone so the exposed circuit board faces upward.
    • Keep the spudger in the speaker while turning the phone.
    • The speaker is indicated by the yellow rectangle.
  10. KDDI Kyocera A5521K Speaker Replacement: Schritt 10, Bild 1 von 2 KDDI Kyocera A5521K Speaker Replacement: Schritt 10, Bild 2 von 2
    • Push the spudger through the speaker opening to separate the speaker (indicated by the yellow rectangle).
  11. KDDI Kyocera A5521K Speaker Replacement: Schritt 11, Bild 1 von 3 KDDI Kyocera A5521K Speaker Replacement: Schritt 11, Bild 2 von 3 KDDI Kyocera A5521K Speaker Replacement: Schritt 11, Bild 3 von 3
    • Grasp the speaker (indicated by the yellow rectangle) with tweezers, or with your fingers if you can manage a firm grip.
    • Firmly remove the speaker.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Dominic Grisafe
157 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 28-25, Regan Spring 2010 Mitglied von Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 13
Insgesamt: 1,842
