Einleitung
These instructions will demonstrate how to remove the speaker from the KDDI Kyocera A5521K.
  1. Turn the phone over to expose the battery cover. Apply pressure to the back of the battery cover to slide it down. The battery cover is now separate from the phone.
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Remove the battery by pushing it up and out from the bottom. The battery, cover, and phone should now be separated. The battery, cover, and phone should now be separated.
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone. Beneath the covers are screws. Beneath the covers are screws.
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. Remove the screws using a Y0 screwdriver.
    • Remove the screws using a Y0 screwdriver.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Use the iPod pry tool to remove the outer screen. Two screws are now visible. Be careful not to crack the screen upon removal.  It is adhered strongly to the phone.
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  7. Use the Y0 screwdriver to remove the screws.
    • Use the Y0 screwdriver to remove the screws.
  8. Use the iPod pry tool to loosen the faceplate from the phone. Slide the pry tool along the entire crease of the faceplate to completely detach it.
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  9. Separate the faceplate from the phone. Separate the faceplate from the phone. Separate the faceplate from the phone.
    • Separate the faceplate from the phone.
  10. Turn the phone over. Place a spudger in the oval shaped speaker opening of the phone (indicated by the red rectangle).
    • Turn the phone over.
    • Place a spudger in the oval shaped speaker opening of the phone (indicated by the red rectangle).
    • Turn the phone so the exposed circuit board faces upward.
    • Keep the spudger in the speaker while turning the phone.
    • The speaker is indicated by the yellow rectangle.
  11. Push the spudger through the speaker opening to separate the speaker (indicated by the yellow rectangle). Push the spudger through the speaker opening to separate the speaker (indicated by the yellow rectangle).
    • Push the spudger through the speaker opening to separate the speaker (indicated by the yellow rectangle).
  12. Grasp the speaker (indicated by the yellow rectangle) with tweezers, or with your fingers if you can manage a firm grip. Firmly remove the speaker. Firmly remove the speaker.
    • Grasp the speaker (indicated by the yellow rectangle) with tweezers, or with your fingers if you can manage a firm grip.
    • Firmly remove the speaker.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Dominic Grisafe
157 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 28-25, Regan Spring 2010 Mitglied von Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Mitglieder
20 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,721
