Einleitung
If your KLH shelf speaker no longer produces sound from the larger speaker this guide will help you get those beats bumping again by replacing the larger speaker.
Was du brauchst
This is what the speaker will look like when you start.
Step 1: Remove the speaker cover.
Step 3: Carefully remove the speaker from the speaker box. Be sure not to break the 2 wires connecting the speaker.
Step 4: Carefully cut the 2 wires connecting the speaker. Make sure to cut the wires about half way from the speaker.
Step 5: Make sure the the new speaker is the same size, and is ready to be placed inside the cabinet.
Step 8: Screw the new speaker back into the box using all 4 of the 2 cm screws.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
