Einleitung
In this Fast Fix disassembly, we will teach you how to take apart your KRUPS milk foamer. Whether it is to fix a small problem or just out of curiosity, this guide will help you make a full disassembly using standard tools and making sure no parts are damaged in the process.
Was du brauchst
Take off the plexiglass top.
Remove the white milk spinner from the inside of the foamer.
Remove the 12mm Torx screws (x3) from the bottom of the foamer using a Torx TR10 screwdriver.
Take out the grey and white power cables by pulling out the slide connectors from the base.
Remove the 16mm Torx screw in the middle of the base using a Torx TR20 screwdriver.
Take off the black bottom from the main body.
Grab the power connector in the centre of the black bottom with a monkey wrench.
Twist the connector clockwise to remove the center power socket.
Remove the electromotor-plug using tweezers.
Make sure to squeeze the small tab on the side of the plug to release it easily.
Remove the rubber housing from the electromotor.
Remove the small rubber cap from the other end of the electromotor.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
