Zum Hauptinhalt wechseln
KYVOL CYBOVAC E20 Front Bumper Replacement
Was du brauchst
  1. KYVOL CYBOVAC E20 Front Bumper Replacement, Front Bumper: Schritt 1, Bild 1 von 1
    • Start with the vacuum on a flat surface.
    • The power button should be on the side closest to you.
  2. KYVOL CYBOVAC E20 Front Bumper Replacement: Schritt 2, Bild 1 von 2 KYVOL CYBOVAC E20 Front Bumper Replacement: Schritt 2, Bild 2 von 2
    • Flip the vacuum over so the bottom is facing up.
    • The dust bin should be on the side furthest from you.
    • Remove the eight 1 mm screws holding the bumper in place using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Front Bumper Replacement: Schritt 3, Bild 1 von 2 KYVOL CYBOVAC E20 Front Bumper Replacement: Schritt 3, Bild 2 von 2
    • Remove both sides of the bumper and replace with new ones.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 227
