Einleitung
If your KYVOL CYBOVAC E20 is having issues picking up trash off the floor or is moving but not vacuuming the floor, use this guide to replace the main motor.
The main motor is responsible for rotating the main brush of the KYVOL CYBOVAC E20, so a broken main motor will result in the device not operating as it should, leaving dust and small trash on the ground.
Before using this guide, make sure to take out the main brush of the device and see if it was out of place or needed replacement prior to using this guide.
This guide requires the removal of the battery and disconnecting ports from the motherboard, so it is advised to power off the device prior to following the instructions of this guide.
Was du brauchst
Start by laying the device on a flat surface with the logo facing up.
Flip the device over.
Remove both sweepers by pinching near the base of the brushes and pulling up.
Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
Disconnect the wheel motor from the power supply.
Remove the nine 15 mm screws using a Phillips #2 screwdriver.
Remove the upper casing of the vacuum.
Remove the dust chamber.
Remove the eight 10 mm screws using a Phillips #00 screwdriver.
Disconnect the plug.
Remove the front bumper.
Flip the vacuum so it is upright.
Disconnect the outer shell from the motherboard.
Remove the single 10 mm screw using a Phillips #0 screwdriver.
Disconnect the motor from the motherboard and remove the main motor assembly.
Remove the four 6 mm screws using a Phillips #1 screwdriver.
Remove the gearbox cover.
Remove the two 6 mm screws using a Phillips #1 screwdriver to separate main motor from the housing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Génial !
j'ai cherché depuis longtemps un tuto sur mon Kyvol E30 et celui-là est très bien fait !
(Le E30 est sensiblement le même que le E20, il a 1 side brush en moins, le reste est identique)
Mon E30 se mettait à faire un grand bruit, comme une vibration.
J'ai ouvert et démonté tout ce que je pouvais pour nettoyer et contrôler, après remontage, c'était pareil !
En fait le problème était au bout de la brosse, le roulement était coincé par un enroulement de cheveux (!) et le cabochon du roulement s'est usé, générant la vibration de la brosse ...
Merci pour votre aide bienvenue !
