Einleitung
Replacement of the LCD board on any Kaffelogic Nano or Nucleus Link coffee roaster with an A, B, C or N prefix serial number.
Was du brauchst
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Hold the roaster steady while removing the plastic top/closure.
Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
Remove the 4x PH2 screws securing the display board to the chassis.
If your ribbon cable is mounted on the front, disconnect it before unscrewing the PCB.
